Scart for virgin box
subseastu
54
Morning all
Just got a samsung 46 inch 7000 series and I need a scart cable to hook it up to my standard virgin cable box. Has anyone got any suggestions for one, budget is up to £100. Info seems to be a bit thin on the ground in these days of hi def and hdmi. Look forward to any feed back.
Andy Clough:Sorry, only just spotted your thread! Suggest the QED Performance Scart which has long been one of our favourites. Should do the job nicely.
That's the one I use for connecting from my Virgin box to my DVD-Recorder. Build quality alone will convice you it's a good cable...when you compare it with a freebie you'll wonder why people aren't embarrassed using the flimsy ones in the box rather than a proper cable.
You won't go wrong with that cable.
