Satellite cable - maximum length
scene
789
187
19,070
I'm looking to run a satellite (coax) cable from my dish to my new extension.
Thing is, I think it's going to end up about 30m long :exmark: Is this a problem?
The_Lhc
1,176
daveh is your man but according to the geezer who fitted my second dish that could be too long, depending on how many bends there are in the cable. I can't actually remember how long mine would have ended up being but in the end he stuck a second dish on instead, which was nice.
scene
789
187
19,070
daveh75 said:
30m is fine providing you use good quality 75ohm double screened cable like Webro WF100 for example (though any CAI Benchmarked type 100 cable will be fine). I regularly use it for 50 - 60m runs, though over that would consider using the thicker WF125.
Thanks for that :)
I suppose the double screened makes sense as well, as this is going to be sharing ducting with the cat6 cable (as per my other thread) - so does that mean I can get away with UTP for the CAT6 - or should I go with FTP - or will I need triple screened coax...
Dave_
1,228
634
20,070
scene said:
Thanks for that :)
The double screened cable will be fine, provided it's the xx100 type cable i mentioned above which has copper braid over copper foil screening, as opposed to so called 'low loss' satellite cable as it usually has inferior steel braid over mylar (metalised PVC film) screening and high losses despite it's name.
FWIW i've got miles of WF100 and CAT5e UTP running in the same conduit/trunking/bundled together all over my house, and haven't had any issues with interference.
scene
789
187
19,070
Thanks for all that daveh75 8) I've got some cable ordering to do...
Not to mention some compression clips and a compression crimping tool :type:
