Sansui TT
Yesterday I was given a Sansui SR B200 tt. Once I'd cleaned up the interconnect, and generally cleaned and dusted it, I hooked it up to my PM4200 and was pleasently suprised at how good it sounded. I cant see much about it on the 'net, but there is a fair bit about the 222 model.
My first purchase today has been the Anti-stat cleaning kit as my old vinyl is a bit grubby in places, but I'm wondering if I should consider replacing the stylus? I don't want to spend much on this as I dont think its worth that much, so maybe I should just enjoy it for what it is. What do you think?
Sansui's, good turntables, have you looked on the vinyl engine site, great for everything vinyl. For around £40.00 only 1 cartridge, AT 95E, may stir up a hornets nest here but much better than the 2m red's and blue's and quite a few more.
Not here; AT make some great cartridges. I heard some folk have used a 95E on an LP12 and enjoyed the end result!
What cartridge does it have? Is there anything wrong with it?
Could be it's a better cartridge than the one being somewhat hastily recommended, and replacement styli are readily available for most cartridges.
Also you need to consider whether the cartridge is a good match for the arm in terms of compliance. As has been suggested, check vinylengine for info.
Your quite right Grottyash about the stylus replacement, could be he has a decent cartridge on it already but i dont believe it's a hasty recommendation, as for the price you pay for a replacement stylus a new cartridge would not break the bank and i cant think of a cartridge that betters it under £100.00. The AT 440MA is a very good cartridge but is rather pricey now as is the Goldring 1000 series. The matching of the AT should not be a problem, as mentioned earlier it can work with arms on tables like the LP 12 which normally come with medium to high mass tonearms or the likes of the duals with a lighter mass tonearm.
Definitely jumping the gun because a new cartridge may not even be needed - the OP mentions the turntable sounds good. Also, if he has something like a v15 on the deck then a new stylus would definitely be the way to go! Lp gear in the states can supply reasonably priced stylus replacements, as can needledoctor and a few others.
By the way check the williamthakker website. The AT95E sets you back a paltry 20,90? and the AT440mla 129,95?. I've dealt with them before, and they were both quick and reliable.
Sorry if the above came across as being a bit blunt. It's what living in Finland does to you!
Grottyash:Sorry if the above came across as being a bit blunt. It's what living in Finland does to you!
What! With all those gorgeous blondes
Thanks all. The current stylus looks to be the original Sansui one. My first purchase on Friday was the Anti-stat cleaner. Then I think the AT95e for about £16 seems to be a good upgrade! Does it just slot in or is it more fiddly than that?
The a replacement stylus is available from LP gear in the US, but costs more than the AT95E to ship here!
Yes, it is a lot more fiddly. You have to set cartridge alignment and tracking force. Vinylengine can help you with an alignment protractor and instructions.
Dunno where I got £16 from ( the replacement Sansui's are £16!) The AT's are about £30-35. Is that about right?
GrottyAsh,
I see that you mention william thakker has AT95e's on another post - I can only find him on the Austrailian 'bay. Does he have a european site?
Lost Angeles:Grottyash:Sorry if the above came across as being a bit blunt. It's what living in Finland does to you!
There speaks a man who has never been to Finland
hammill:Lost Angeles:Grottyash:Sorry if the above came across as being a bit blunt. It's what living in Finland does to you!
I only ever go south, perhaps my Finns were Norwegians then
