Hi
I've noticed my new TV screen is not vertical but leaning back at the top. It's 25mm closer to the wall behind the screen at the top edge than the bottom edge. It's mounted on its stand which I have double checked is properly fitted and the cabinet it's on is level. Is this normal and intended design? Does anyone else have this TV and could check theirs?
