Samsung UE40F7000 v UE40F8000
BigDefender
Is there any significant difference between these 2 televisions? I'm interested in watching sports so if one is better than the other for that it's a deal breaker.
Thank you.
Some people are very rude i would have thought you would have an answer by now, as for me i don't know so i can't help sorry.
Don't know either, can you demo? One would think the F8000 would be better, I think I would buy it. Oldboy bought it and loves it. From demos the blacks look good too. These are the best prices:
http://www.totaldigital.biz/index.php?main_page=index&cPath=43_51
Price match with John Lewis, then if you think the TV is not up to snuff get it collected. That is the best answer I can give. 🙂
I can certainly recommend F8000 I never compared it against F7000 so a demo would be best.
For 40" price difference is £175
I compared the 2 side by side in John Lewis. I then compared the 2 in Richer sounds where they turned the lights off so I could check out the black levels. I couldn't tell the difference. They both looked good to me. I ordered the 46" 7000 on-line from John Lewis with a price match to Richer Sounds. That way if I don't like it I can return it under the Distance Selling Regulations - no questions asked. I have a plasma and have found getting a decent LED replacement a challenge.
