SAMSUNG LE40B650T OR SONY 40W5500
I keep flipping between these 2, i had plumped for the sony, but having checked the pictures again and not so sure now, plus the samsung is about £100 cheaper. Anyone got any views on either? anything would be much appreciated. Also i have just purchased a s550 blue ray, would the samsung be ok with this?
Is it worth buying power cables instead of the free ones you get? will it really make that much difference?
BTW is this the same as the 651t on dixons website? any views would be much appreciated.
i dint really want to spend that much, though must admit the 7020 is very very nice
Try the X series from panasonic, they look nice, although, i have not tried it yet!
evolution:i dint really want to spend that much, though must admit the 7020 is very very nicewhats your budget ? do you want to buy online , in a store ? 7020s prices differ quite a bit ...
my budget is about 900, i will probably buy online, but wherever i can get the best deal really
evolution:my budget is about 900, i will probably buy online, but wherever i can get the best deal reallybest online price for the 40b7020 is £1145 , i think you can get the le46b650 for £1000 though , very good tv and price ...
of course , but if you wanted a 46 inch thats a great price , if you would prefer a 40 inch then the sony and sammy you first mentioned look the best choices for your budget , just my opinion , they do look the obvious choices ...
i would love the 46inch but i doubt the missus would let me, she thinks the 40 inch is to big! im still not sure, im thinking the sony because i have the s550 blue ray, though not sure it would make that much of a difference
