Ruark Sabre III still competitive in sub 1k market?
Audioholic
34
Hi guys
This is my 1st post on the forums here - I currently have Monitor Audio BR2s which I really enjoy, that are being driven by a 27yo Pioneer amplifier - the SA130. My source up until now has been an Arcam rDock with a mixture of lossless and 320kbps AACs which has bipassed the iPod's volume control to use the DAC of the amplifier. The lounge which the system is in is 18" by 12,6".
Because I've been saving for a bit and currently have pretty few sources of expenditure, I could now upgrade my system. To me, the obvious component to change is the amp, but strangely enough to really get one that is much of an improvement in overall music delivery I think I'd be looking at something in the price range of the Naim Nait 5i. I've compared the Pioneer, not in an A/B test, but using the same speakers as a kind of constant, with the Marantz PM6002 amp, and their was very little discernable improvement, apart from less muddy bass and some better separation between instruments so the sound was a little more crystal - not that I'd exactly call the exisiting sound mushy, but perhaps not quite as clear on the faster and more complex songs.
Although I'm sure many here go by the source 1st philosophy, I deliberately chose the Arcam rDock because I thought that it allowed it to not be too much of a limiting factor on performance with other equipment, because it effectively just acts as a transport. I am however strongly considering getting a CD player once I change the speaker and/or the amp and am pretty set on the Arcam Cd192 (I don't want Cyrus) because I like it's sonic attributes and it can be had ex demo or s/h for a very good price!
However arguably the most critical determinant of the performance is the speakers and their synergy with the rest of the system. I am going to a local hifi store tomorrow to listen to some speakers - namely the PMC DB1i, Neat Motive 3, the Epos M12i and Proac Studio 110.
However, unfortunately at the moment he does not have the Ruark Sabre IIIs in, and I think partly just due to the fact they're not a very active brand now in releasing new models, his feeling is that they're not competitive as they were and have been slightly eclipsed by improving competitors.
What I want to know, from anyone whose heard them, is are they definitely worth hearing in the sub 1k monitor market before buying anything else.
Just to ask a slightly hypothetical question, basically, if you had the option of partnering with any mid priced electronics of your choice and you wanted a system that majored on being quite exciting and dynamic + had a pristine-like sound with high frequencies, taut impactful bass but not necessarily bass that's very loud, as well as the ability to create some space around the instruments (quite a long list of requirements I know!), which standmount or compact floorstander would you choose up to £900. Would you favour the Ruarks over any/all the speakers mentioned above.
At their RRP they are comparatively expensive, but if I could get ex demo ones for £600 would you consider that good value?
Basically I have the chance to listen to all of those speakers, except for (atm anyway) the Ruark, and wondered whether it was worth holding out trying to hear it? Avreview, here and another mag all rated the Sabre IIIs highly but I see it doesn't get alot of mention when recommendations are made now, so perhaps it's been eclipsed by competition.
I personally really like the sound of what it can bring to the table though! Of course your opinions are really welcome & thanks very much in advance!
Jonny
At £600 they are good value and they are also good speakers. Whether you like them (and whether they match your ageing amplifier) is another question and one only you can answer. For what it's worth, I've heard them and all the other ones listed and owned the P.A 110's. I like them (sabres) because they are not the usual woolly sounding monitors with warm, flabby bass but then none of the ones you've mentioned are if partnered sympathetically. Incidentally I owned the Mark II version and whilst different, the quality of finish is lovely. Take your time, travel if necessary and see what you think.
Another option I'd warmly recommend is to get in touch with AVI and arrange to listen to their 9.1 active monitors. They incorporate a quality pre-amp, DAC and obviously amplifiers, very powerful ones. The matching issue is taken care off and they sound fantastic. Maybe you like them, perhaps not but from what you said about dynamics and pristine high frequencies, they are imo unmatched at and considerably above their price which is around 1.1k. Somewhat over your budget but then you get a whole system.
Whatever you choose will be a significant step up from your Monitor Audio Bronze's but it will most likely unbalance your system and you will need to upgrade around the new speakers accordingly to get the full benefit.
matthewpiano:Would be interested in how you get on with the Epos M12i. I'm seriously considering these myself.
I know your question was'nt directed at me but perhaps try some KEF iQ7 (non-SE) or 9's. They both sounded sublime with the 1500 and a DacMagic using a denon player as transport. Lots of negative views in this forum about the larger iQ's but I've yet to hear better value for money at todays discounted prices. I particularely liked the predecessor the the M12i and certainly worth trying with your Denon.
Sure, I'll let you know after I hear them tomorrow! Just so you know, I will be listening to all the speakers partnered with the Arcam CD37 tmorrow, cos as far as I'm aware, it's the closest thing to the Cd192 (which I hope to be the long term player in my system) from Arcam's current cdp range.
Thanks very much for your feedback Drummerman, I'll try and make sure I listen to those AVIs!
I know that the Ruarks have quite low claimed sensitivity of 86db, although not massively high watt range or whatever it is, up to 120w.I wondered in layman's terms if someone could give me an idea what kind of amplification the Sabres would need?!
I know Clare from the editing team at WHF, in a previous thread on the topic of the Sabres, said that they might suit quite a tonally neutral amp such as the Arcam A32 or being biamped through the A32 and P35. Basically because their refined pure sound would not expose the Sabre's problem of slightly excitable/ aggressive treble. With this in mind, I wasn't sure if the Naim nait 5i and cd192 combo might be in danger of exacerbating this, or is the latest Nait 5i refined enough to avoid this problem?
As a sign of my un-audiophileness (no, that's not a word) I really couldn't bring myself to spending hundreds on cyrus, irrespective of how it sounds in fact, cos I just find it really ugly. I know that sounds really bad, but the only positive is that it does make it easier to have a shortlist of amps!
So my amp options for driving the Sabres would be Arcam A32 (could add P35 later to biwire), Roksan Kandy K2, Cambridge audio 840c or the Naim Nait 5i. Once u start looking over a grand there's obviously a mass of other stuff, but I think that would be more than I can justify right now, esp. seeing that I got my current amp which is pretty solid if not spectacular, for free from my driving instructor!
Cheers guys, jonny
Interesting. You are probably trying to tell us in your own carefully chosen words (word
)that you just heard a Denon PMA1500AE and found it to be better/equally good as either the K2 or Arcams top A38 (or 32 plus poweramplifier) at far less cost than either one of them. Gratulations.
drummerman:
Thanks Drummerman. I'll take those suggestions very seriously as it was you that put me on to the incredibly good Denons.
I'm a big fan of the M12i speakers. They're not flashy looking but they sound brilliant, let us know how you find them, but for the money.....or for much more in fact..... you will be very very happy with them I'm sure.
In the instances of some songs I preferred the Epos M12i to the Neat Motive 3. I would say the typical attributes of the Neat motive 3 were of a leaner sound, which was more foreceful and definitely more forward. I also thought although they seemed to narrowly reveal that much more detail, their accuracies came at the expense of harshness sometimes. I don't know what cables he was using, but that was just my impression.
The Epos M12i was a bigger sound (probably not surprising considering it's a bigger cabinet) and they both definitely had their strengths and weaknesses. If they were the same price, I'd have a hard job deciding. The Neat motive's were exceptionally rhythmical which complimented the Nait 5i, but when I listened to Smotth Criminal by Michael Jackson with them, I found MJ's voice slightly veiled, and the instruments seemed to have precedence over him. I just didn't find that song as fun as I expected, and for enjoyment factor (in the case of this song) preferred it when I previously heard the song on the Arcam Solo mini (and even more so on the Arcam Solo music).
I think I'm going to have to listen to some more combinations with this amp, although I definitely was impressed by both speakers, but at their prices if I had to buy one now, I'd go for the Epos M12i no question. It would have been good to have heard the Neat Motive 2 too though!
I know I'm going on about it, but if I put enough pressure on the store, they'll probably able to borrow the Sabre III's. Do you think they could be step up from the Epos M12i, or just a sideways step? Do you think they'll go well with the Nait 5i. The closing paragraph on of the review of the Sabres said
'The treble is highly detailed, but can occasionally become hard and aggressive. But if you sensibly choose balanced or smooth-sounding partners, then you'll hear the Ruarks at their absolute best. And their best is just so incredibly musical, it's well worth the occasional treble flaw''.
Do you think the Arcam is balanced and 'smooth sounding' enough, or shall I try hear them with an Arcam FMJ amp, like the old A32, or A28? WHF's review also says to hear the Sabre's at their best it's best to biwire them, which isn't an option on Naim's current gen entry level amp. OTOH, the Sabre's and Naim's sonic signature sound similar, so might it be that they compliment each other well? Any thoughts and opinions really welcome!
Jonny
Jonny
