- Jul 13, 2008
- 15
- 0
- 0
denontillidie said:Hi,
I currently have a RA-1062 amp running a pair of B&W 683 speakers with a denon 2012 universal player as my deck.
I have recently come into some money and am looking to upgrade my amp to something nicer.
I have looked at the marantz pm15se amp and the roksan caspian m2 amp.
I am open to suggestions and some good advice, as i have plently of good shops round here, but short of time due to a young family.
Cheers,
Rob Owen
Cheers,
Rob Owen
denontillidie said:some nice ideas here. I mainly listen to classical and jazz, some electronica and prog rock. I have a medium to large front room and the speakers are 3m away from me and 2.5 m apart, also well away from the walls.
I am looking to do something, as the system overall sounds a little forced at times and a bit rough around the edges, plenty of power but not a lot of refinement (a bit like a 6ohm system).
If you think that my amp is tasty (cheers lol), then maybe the speakers could do with a upgrade. I heard some CM9's in yodobashi in tokyo recently, and they were gorguous. But they did not have any rotel amps, and had them running through the afore mentioned marantz. but i have no idea if the cm9's would work well with my amp.
I also have chord silverscreen cable running in biwire, if that is any help
