Roksan Kandy K2 for a turntable based system?
peter312
11
I am looking to set up a turntable based system in my home office and would appreciate some feedback and thoughts.
I have not bought any equipment yet, but the turntable will likely be a Pro-ject or Rega up to about £400 or so. I also have yet to decide on speakers, but they will need to be smaller stand, shelf or wall mounted. I seen a Roksan Kandy 2 amplifier at a really good price and would appreciate peoples thoughts on it. I mostly listen to 70's and 80's pop (e.g. ELO, Queen, Fleetwood Mac, Ultravox) and classical music (although not opera).Many thanks
Hi there,
the marantz pearl lite is a great sounding amplifier. You can compare it to the roksan at Superfi. Give them both a listen and let us know how how you get on.
cheers tonky
Best to go for any amp with built-in phono stage. So look at Marantz, Arcam, Rega, Rotel... but do try and audition before buying then at least you'll know what speakers will be best with the intended amp.
An £800 turntable and a £400 amplifier makes far more sense than a £400 turntable and £800 amplifier.
Spending loads of an amp won't necessarily lead to any improvement in sound quality but spending more on the turntable and speakers will.
The K2 has been out a while now and I seen it new for under £650, so its good value, my impression on 2 demos was its has quite a bit of power and bass but lacks in clarity. I note a few users on here have soon upgraded from it. The best amp I heard it that price range was the Creek 50A but I don't think it has a phono stage, so you will have to add £80 or so for that. For your sort of music I would look at the Rega Brio R and maybe Arcam A19, Marantz Pearl Lite also worth considering.
My wife and I auditioned the Roksan K2 against the Marantz Pearl Lite, and bought the Roksan. Power, depth and insight, with a much more rhythmic bass than the Marantz. Superb build quality as well.
And there was me thinking the Roksan had an inbuilt phono stage, and quite a good one at that. 🙂
The Roksan amps I have owned have all had excellent phono stage as you would expect from a class turntable manufacturer!
Yarp - I was trying to avoid a duplication. I presume the OP knows that the Kandy has a in-built phono stage.
He does now!
Sorry PP but the way I read your post sort of implied it didn't so he'd be better going for something that did...if you see what I mean.🙂
I own the Roksan Kandy K2 an excellent amp or its price ,However the the build-in phono stage is decent but not great maybe you should consider
an amp and external phono stage .
He does now!
Fairy snuff. The same way, I suppose, if the OP has titled it: Arcam amp for a turntable based system, I wouldn't mention Arcam again with any of the suggestions. Know wot I mean, Al... 😉
He does now!
Gotcha! He said with a knowing wink. 🙂
