Roksan Caspian Mk1 upgrade
cse
97
I'm considering upgrading my old Roksan amp. I'm looking for something with detail, good sounstage but with a warm engaging listen. I enjoy mostly classical, but also early Van Morrison in particular. Any ideas appreciated.
£700-£800 new? will be quite difficult as the Caspian is a very good amp. Have you compare it with the newer model, M-range?
CA 840A may be? but it would be a change rather than proper upgrade I think
. Need more budget I reckon.
Some idea of kinna system you may like to demo.
Opera Audio Consonance Reference CD-2.2 MkII - Roksan Caspian Mk1 - Roksan FR5
Pathos Digit - Roksan Caspian Mk1 - Opera Seconda
imo anything in the 7-800 quid range is going to be a lateral move at best. Do you really think the Caspian's your weakest link? Most people feel it's quite a strong amplifier. Mayhaps you might want to look into biamping? Could pick up a Caspian poweramp for that easily I'd think.
Thanks. I'm not sure that I fully understand bi-amping. How does it work with bi-wired cables? Do you need anothe interconnect between the new power amp and the old integrated amp? Woul the old integrated amp, with a power amp, sound as good as the original pre/power amp combo?
Thaiman Thanks but i don't want large floorstanders and i already have a Densen CD player. Have you heard their amps?
cse:Thaiman Thanks but i don't want large floorstanders and i already have a Densen CD player. Have you heard their amps?
I have own quite a few Densen in the past including a pair of B350. The lower range like B200/B300XS I had was tremendous value, the combo had all the timing and resolution that put many similar price amps to shame. Up the range, however it's a different story. I (and a few friends) thought my current ECS beat the top of the range Densen by some margin and Densen cost £1400 more! Too cloloured for my taste.
Digital side of thing....The 400XS cd player is go to be one of the top 5 "best CD player ever made, I reckon".
Thanks Thaiman. what about the B300. ebay has it for £375 but it now. Could I then use it with my Roksan acting as the preamp?
My old XS is a little better but I sold it for £600ish so the one on Ebay seem to have a value on it side. I am not sure how good is the pre on Roksan is though.
