[Edit: I finally got myself:
- A SMSL SA-50 T-amp (~65€)
- Eltax Monitor III speakers (got them second hand for 75€, they're almost new)
I'm happy about the sound and would recommend them to anyone looking for a decent HiFi system.
Thanks all for your help.]
Hello,
I want to get myself a pair of speakers in order to enjoy my music (CDs and FLACs). The speakers will be connected to a Fiio E10 DAC (didn't buy it yet) which has a headphone amp, and be placed in my average-sized room.
That means I need either an external amp + speakers, or speakers with an internal amp. The latter suits me the most because my budget is tight, 100€ approximatively (~$100).
Right now, I have no idea of what kind of speakers to choose. There's many choices:
- PC speakers, but as far as I understood they are not the best choice for good sound quality, is that right? What do you think about Bose Companion 2 for example?
- Stereo systems. With my budget I can't get a new decent one, so I was thinking about getting an old used one. Do their sound quality deteriorate over the time?
- Monitoring speakers. They're also expensive, so I can get two used ones. But are they "good" for music listening? (getting a new Hercules XPS 2.0 80 DJ Monitoring is in my budget though)
- An external amp with a pair of second hand speakers (like this or this)
I need some expert insight about the points mentioned above, and some advice about models of speakers I can get with my tight budget.
What would you do if you were in my shoes?
Thank you very much.
Hello,
