replacing rotel ra 840 amplifier
dbg
Hi.
I've got an old rotel ra 840 amplifier which I'm looking to replace with a new unit. Can anyone recommend a modern equivilant that would give the same sound quality? What sort of price range would I be looking at? One potential snag is that it would need to be the same size or smaller, since my hifi cabinet is homemade for a perfect fit.
dbg said:
Hi.
Welcome to these forums
Can you please provide the measurements of your amp?
It would also be helpful tell us what speakers you have and room size.
Hi, I think it would probably be best not to squeeze an amp into a small space but give a greater amount of ventilation, especially on top. I first had a look at the Rotel RA-10 but don't think it will fit. The Creek 50A should fit though so you could try that. Bt the way, I'm going by the size of the Rotel RA-840 specs so no idea what your actual cabinet size is.
amp measurements are 430 x 299 x about 120mm. room size is about 5 x 6m. there is a little extra room depth wise. the height can be varied. at the moment the amp is stacked with a tuner on top. theres still a couple of cm above this. the tuner can probably come out though as i dont believe its been used in years and im not sure if its working.
speakers are bose 101s
I think the Creek 50A is a good suggestion, and should sound pretty similar with your old Rotel. And so is the Rotel RA10 if you can fit it.
If you wanna overhaul, look at Naim 5si, and change the speakers to XTZ 93.23 mk2, Dynaudio stuff or Focal Aria 906.
Al ears said:
MUSICRAFT said:
Hi dbg
Also look at discontinued amplification and the NAD C320BEE.
All the best
Rick @ Musicraft
The NAD is slightly wider than his Rotel but not by much (5mm) it is not as high though.
I have a NAD320BEE which I just upgraded to the Abrahamsen and it is 435 x 115 x 320 (including speakers binding posts).
rmatthew said:
Al ears said:
MUSICRAFT said:
Hi dbg
All the best
Rick @ Musicraft
Yep, that's right.
