Rega P3 or Technics SL100C
Rega are local to me (and I've worked there), so I shouldn't be disloyal......but.
I've always liked the look of that 1500C 🤔
I would be interested to hear both decks, using the same cartridge to play the same 12" 45rpm test vinyl.
Not least to also hear what the built-in phono preamp on the technics is like.
Reactions: DougK1 and RoA
I was more thinking about the 100c as I do not need the pre amp or the included cartridge but yes, I get why you think so.
Ideally I’d have the Technics deck with the Rega RB330 arm but lets not go there 😀.
My interest in vinyl this time round is limited and does not warrant a big outlay just as it didn’t with my recent purchase of a cd transport. I stream at least 95% of the time.
Hi, you have opened very interesting thread. I am 26 years user of Rega turntables, P25 and P9 2nd generation. So I have afinity to Rega. Technics is very good, reliable brand. They have produced around 4 milions of turntables. Technics has more massive sound with a bit boosted bass and a big slam in bass (typical for direct drive turntables). For rock, pop, metal, hardrock, electronic this will be better. Rega typicaly is very precise, rytmic and dynamic sounding turntable. It has also better 3D image but less massive bass. For jazz, soul, new age, vocal, classical music I think better. Technics has also some typical comfort features like autostop at the end of LP. Rega is fully manual. So choice is up to your taste and your system. Rega is very good when used with their cartridge, phonopreamp, amp, speakers etc. There is a real synergy. Technics will need also very good cartridge to show its best. I recommend you to read very good review from Mr. Fremer: https://trackingangle.com/equipment/technics-sl-100c-is-a-grand-bargain
BR.
I think this debate is very similar to the recent one here…
