rega mira 3 dip switches.
bonenut
9
hi,i am trying to locate the internal dip switch that switches of the power amp in a rega mira 3.the gain dip switch is easy to find,but i cant for the life of me find the power dip switch.its clearly stated in the manual..any mira 3 owners out there.cheers.
Just a nagging memory (never owned the amp) but wasn't that link switch removed in later versions of the amp.
Best to contact Rega direct to clarify.
thanks for your reply,after more extensive serching(both inside the machine and online)i found a few threads from people saying that they had the later version with the link switches remove.thanks for your help.
