- Sep 20, 2016
- 2
- 0
- 0
Hello everyone - I hope you are doing well. I am a new member and recently have been doing a lot of research and purchasing for Hi-Fi gadgets for my listening pleasures. Now 2/3 weeks back I purchased a brand new Rega Elex-R amplifier to power my Magenepan 1.7i speakers. Just so that you know this Rega amp has got 5 inputs. Input 1 is for Phono. Input 2 through 5 is for external sounds sources to connect through RCA cables.
Now here is the issue I am facing: If I connect my music source through DAC to Rega's Input 2. Select the Rega to Input 1 or Input 3 and increase the volume of Rega towards the high maximum (say towards the last 3/4th of the volume dial) then I can hear the music bleeding from Input 1 in faint volume. Now keep in mind this sound does not appear to be an electric buzz or hum. It is just that same music which is coming through the DAC albeit in very low volume. Shouldn't Input 1 and 3 supposed to be clean and dead since I have not connected anything to those Input 1 and 3 ?
I don't think I get this bleeding problem if I connect the DAC to input 4 or 5. I can try again to check.
I was wondering if this is normal behavior in such an expensive amplifier or can it be a cable issue ? I was thinking if this a bleed is normal then it should happen when I connect the DAC to any input from 2 through 5. But why only Input 2 ? Did I get a faulty amplifier from Rega and ask for a replacement?
