Recommended speakers for 7m x 7m room
Having a new extension creating a 7m x 7m room and would like to use the opportunity to install a surround sound speaker system so I can have 4 speakers in each corner, any recommendations? I've looked at the Bose Acoustimass 10 system already so that's my budget.
Sorry I mean a speaker in each corner but I'm assuming that will give me the sound coverage across the room which will be a kitchen/diner/tv watching area. I'm looking for something small but which gives good performance so the Acoustimass 10 took my eye especially as they come in white as well. Just wondered if people can suggest any alternatives?
leenorm1
10
Hi that is a big area 49 square metres that's thx select size. I fear the Bose system will not do it. They are good at what they do but that's a big room. You have to decide what you want , small speakers that hide away but don't fill the room or bigger speakers that will fill your room but make themselves noticed. I always find it best to decide what I want then work out how to achieve it.
