A admin_exported New member Aug 10, 2019 2,556 5 0 Dec 15, 2008 #1 Happy Christmas, Your recommendations please for a Docking Station for the I pod nano Thank you all.
M manicm Well-known member May 1, 2008 2,542 1,078 22,570 Dec 15, 2008 #2 All-in-one or connected to hi-fi? Budget? If former, there are many from budget to high-end. Check out WHF's reviews right here, it will give you some idea. If the latter get an Apple dock, or if your budget can stretch and have a decent hifi consider Arcam's rDock.
A Anonymous Guest Dec 17, 2008 #3 I use a Logic3 iPod dock connected to my Pioneer LX51 by USB which works great. Not tried it connected with phonos though. Check the compatability with your Nano though. Happy Christmas all
G GetCarter New member Nov 5, 2003 21 0 0 Dec 17, 2008 #4 The type of dock you buy will also depend on two other things. 1. Are you wanting audio only or video as well? 2. what version of the nano do you have? Both of these also will determine which docks will/wont do what you want. ÿ
