reccession busting av stand/cabinet...
i need one that can fit four components , avr, cdp, stereo amp and bdp, preferably two up two down, one with wheels would be handy too, and it needs to be strong enough to take a 50in plasma on top..
budget is £150-£200.. thats a bit low i know, but im hoping it can be done, im not expecting anything made of top quality materials, obviously, just something half decent looking.. any suggestions?? thanks...
ooh, thanks guys there are a few cheapies there ok, there's an ikea in dublin too, dont know why i didnt think of that, ill give em a ring in the morning to check stock, and to see if those cabinets will hold a 50incher
grdunn123
293
6
18,895
Max, take a look at the Techlink stuff on Amazon....I have the Avatar PTV2 which is very good and will take all 4 components and the plasma tv. There's 2 versions one with a built in tv bracket and the other without. Thick glass shelves which can support 100KG for the top shelf and 50KG for the lower 2 shelves. £187.99 delivered
grdunn123:Max, take a look at the Techlink stuff on Amazon....I have the Avatar PTV2 which is very good and will take all 4 components and the plasma tv. There's 2 versions one with a built in tv bracket and the other without. Thick glass shelves which can support 100KG for the top shelf and 50KG for the lower 2 shelves. £187.99 delivered
ah cheers grdunn, amazon deliver free to ireland too, ill have a google for that, it sounds like a decent quality item
f1only
278
Mines a Ikea MDF in light oak jobby cost £60 ish if i remember correctly in a sale, it takes up to a 50" & 5 of my components - Amp, BD, DVD/HDD, ps3 & V HD Box.
Pistol Pete1:
If you like the idea of Ikea.......maybe this would work?
http://www.ikea.com/gb/en/catalog/products/80102151
Add wheels/castors onto the bottom.....and voila.....job done....
(I was considering this one a while back)
looks ok to me pete, its 38cm high, i suppose that would be enough, i wonder would it be a bit tight for my avr? it would fit but would it get enough ventilation?
f1only:
sounds good, looks like ikea is the best bet for value
Pistol Pete1
248
maxflinn:Pistol Pete1:
Shelves are adjustable........your Sony S370 above it might work....it doesn't need much room.....
Pistol Pete1
248
f1only:
Supports all my gear no problem & is supported in the middle i took the castors off though as i didnt intend moving it about.
Fair enuf......
But Max's tv is a little bit bigger, and probably heavier too.
Pistol Pete1:What's the max size for this stand, Max? (Width, in particular)about 120cm pete
Pistol Pete1
248
f1only:
maxflinn:Pistol Pete1:What's the max size for this stand, Max? (Width, in particular)about 120cm pete
Whats the minimum size?
Width of two hifi/av units (90cm) plus any wood/glass sides, I reckon......
thanks pete, ill have a look at their irish website and shortlist a few, then take a spin up to dublin to check them out in the flesh, i dont know if ikea ireland will stock all that ikea uk does, they definately seem the best choice moneywise
