Which one?I have just found a high speed Ethernet HDMI cable, that should be fine right?
It seems to be working eg Picture quality. Not sure which one mate.Which one?
Tried the EU one and US but no firmware update working.Got most things working but just can’t seem to do the firmware update via USB stick. I guess the EU one is right not US:
REAVON UBR-X110 Support - Firmware and Downloads
Firmware updates. On this page you will find the latest versions of firmware and software for the Reavon UBR-X110 4K Blu-ray player.reavon.com
I am still not 100 per cent convinced the Reavon is playing 5.1 surround sound correctly on SACDs. It seems a bit quieter compared to the CA player. Everything else is perfect.
The output of the player might just be lower than the CA. Just means adding a little more gain on the amplifier.I am still not 100 per cent convinced the Reavon is playing 5.1 surround sound correctly on SACDs. It seems a bit quieter compared to the CA player. Everything else is perfect.
Thanks David. 👍The output of the player might just be lower than the CA. Just means adding a little more gain on the amplifier.
Thats a good price Gel. Doesn't help you i know.
Gone back to £900 the RRP of these just a misprice Yesterday.
Anyone got any idea why the Cambridge Audio says SACD PCM and the Reavon just says SACD.
Thanks Bill. 👍SACD & PCM are different types of digital information with the most common being PCM, which any DAC can decode and why most players that support SACD allow it to be converted into PCM.
Sometimes it is just mentioned in the manual, other times manufactures stick it on their equipment, CA obviously decided to make a point out of it.
Bill
