- Aug 10, 2019
- 2,556
- 5
- 0
3 months ago I moved from my parent's house to a flat in central Manchester. Ever since moving out, when watching films on my 'home cinema' setup, there is an occasional high pitch noise that comes in at random points that either lasts 2 seconds, or lasts an indefinite length of time (never shorter than 2 seconds, never between 2-10 seconds).
This is my setup.
http://farm5.static.flickr.com/4141/4779880963_bf0004b150_b.jpg
This is a very homemade setup - I am using an old Amstrad amp (which is fine), a Panasonic Viera 46" plasma TV,two Fidek studio speakers at the front and 2 Yamaha studio speakers at the back with a sub which also acts as a junction box and powers the left and right rear speakers.
Before moving to this flat my setup was slightly different. The DVD was plugged into the mixer using a short phono cable, not a 15m one, and then the cable between the mixer and the amp was also a short phono cable. The only long 15m phono cable used was to run to the rear speakers at the other side of the room.
I usually have a PC running into the mixer too (as I did at my old house).
I have tried probably about 30 different things to try and eliminate the problem and to diagnose where it is coming from. I am absolutely stumped now.
- It isn't the speakers because I have tried many configurations with headphones only and it happens then too. - It isn't the amp because it happens when I just plug headphones into the mixer and not use the amp at all. - It isn't the mixer because I tried cabling it using a splitter so that the mixer wasn't involved at all, and it happens then. - It isn't the cables, nor their length, because I've tried it with different cables, swapping cables, using only short cables, unplugging cables, using only the front speakers with no long cables involved at all (only short ones), and it still happens then - It isn't the DVD player because there is no high pitch noise if I plug the DVD player audio cables direct into the TV and then plug headphones into the TV - It also happens even when the DVD player is switched off - It happens even if I run the audio cables from the TV to the mixer instead of DVD to mixer - It isn't the power sockets because I've tried plugging the amp, mixer and DVD player into an extension lead plugged in at the other end of the room and it still does it (and it won't be the amp/mixer/DVD causing it because I've already pointed out how none of these are causing the problem) - The long cables were originally running alongside a LAN cable and lots of power sockets - to test if it was interference from these, I moved the cables. It still made the high pitch noise - I have tried unplugging my router and repositioning the router (which usually sits on top of the DVD player and is plugged in at the same wall as the DVD player, TV and amp) to see if it is this that is interferring. The noise still occurs - It isn't the rear speakers because it happens when they're off and it happens with headphones as aforementioned - I have also tried the cable configuration that I had at my previous house - the sound is still there[/list]
Has anybody got any idea what the heck could be causing this problem? It is driving me insane!
Someone suggested it could be interference from cab radios?If it is, then it is interfering in exactly the same way with every element of the setup because as aforementioned I have isolated each element (e.g. the amp,the mixer, the cables) and it occurs on every isolation, so if it is interference, then each element is responding in exactly the same way.
Any help would be greatly appreciated.
This is my setup.
