jakja83:
Which DAC would you use with the Rotel RA-1520 on a pair of neutral speakers?
rDac is a cheap alternative, but a bit boring soundwise?
Rega?
Hi jakja83
Rega's superb DAC will provide a quality signal and importantly should also be a far better tonal match to help keep in check the forward/upfront presentation of the RA-1520.
Thank you for your help, actually I will use it with PSB T6 floorstanders and I think I will use a Nuforce HDP with them, in that way I get a headphoneamp as well.
