- Oct 7, 2014
- 2
- 0
- 0
Hi, I've just started playing records after stumbling upon a bundle of LPs and buying a Pro-ject Elemental turntable. I've got a few questions about vinyl care that I couldn't find answers to elsewhere, so help a newbie out 😀.
1) Does it damage the stylus/LP if you accidentally play the centre of the record (the smooth part)?
2) Will you damage a record if you store it with a bit of dust or static on it (even if you use this record often)?
3) Are there any DIY or low cost ways to de-static your records?
4) Should I clean both sides of a record before storing even if only one side is played?
and finally
5) Does keeping the rubber loop (the one used as a pulley thing) on the turntable damage the motor/ plinth/ the rubber itself?
Thanks!
and finally
Thanks!
 Facebook
Facebook Instagram
Instagram
