bluedroog said:Yes it just switches from your computer to 'mysqueezebox.com' that's what is does for internet radio anyway, I assume it's the same for Spotify. So yes, you can use these services without your library of music location on.
jonomd said:Does that mean if computer is switched off and no nas the squeezebox is of little use.
Already have a yamaha hard drive recorder which has my music so no need for nas drive.
It would have to work with computer off.
problem. You ay not find the inboard software that able. Most users have the software installed on the NAS or pc.DIB said:jonomd said:Does that mean if computer is switched off and no nas the squeezebox is of little use.
Your opening post asked for a source that provided Spotify and Internet radio without the PC being on. The SBT does all that very well indeed. One of the things I really like about the SBT is the fact that when I come down in the morning I can switch it on and have the internet radio almost immediately, a matter of only a couple of seconds to start playing.
If you want to stream music to it then whatever it is stored on (PC or NAS) would need to be switched on, or I believe you could put a load of your favourite stuff on a USB stick and plug that into the SBT.
jonomd said:Thats offered a bit more clarity now. Still looks as if it could do a job though. One day the hard drive on the yamaha will die (it is 6 years old and cannot be backed up) so may be worth starting a backup hard drive now for when this happens.
Thanks for the help.
DacMagic or DacMagic Plus?Sysagent said:Or...
You can just connect an external hard drive connected via USB to the Squeezebox Touch rammed to the gills with High Resolution FLAC files, install Toolbox 3 on it and have a pretty damn good audio experience. The Squeezebox Touch has it's own on-board Squeezeserver lite on it that allows you to access external USB devices, you can also share the drive and add files to it from another computer if needs be.
Make sure that that the external hard drive is formatted either FAT32 or NTFS, that it is a Primary partition and there are no image files on there greater than 300KB or else you will run into problems.
I have just upgraded from the Squeezebox II to a Touch (it arrived yesterday infact) and I got the unit from eBay brand new sealed in the box for £169.99 and it's a worthy upgrade path just for the simple fact it supports high resolution files out of the box and does not need any SOX re-sampling to occur.
Just got my eye on a Cambridge Audio Azur DACMagic on eBay at the moment to complete my hifi upgrading and then I think I have spent enough for the next few years.
Russ
