question for the what hifi team or trevor
how does one like trevor in a past review of the Monitor Audio RS8s go about "modifying the crossovers replacing with 'Clarity Caps' bypassing them with Vishay MKP 1837 0.01 polys"?
sounds difficult! and do i need to do this to mine?
ta
eamo
I wouldn't worry about any of Trev's posts.
Did you see that wind-up, "Hitting the sweet spot"?
http://whathifi.com/forums/t/183758.aspx
Complete nonsense.
eamoi: how does one like trevor in a past review of the Monitor Audio RS8s go about "modifying the crossovers replacing with 'Clarity Caps' bypassing them with Vishay MKP 1837 0.01 polys"? sounds difficult! and do i need to do this to mine?
Are you happy with the sound you're getting from them now? If yes, then no, you don't need to do it.
Either way, if you need to ask, you probably shouldn't be attempting it.
LOL
indeed iam happy with the sound... breaking them in nicely! dont fancy fannying around them with a screwdriver and a steak knife! LOL
Leave them as they are; if there were supposed to have better crossovers etc im sure they would have sorted that from factory 🙂
