Hi all,
I recently go to a home theatre shop and find some new powerred subwoofer models from Wharfedale and JBL equipped with 3 RCA connection which are dedicated for Left, Right and LFE. My question is, can all of them hooked up simultaneously from AVR's multichannel pre-output?
Previously I posted a thread "We may need a 5.1 subwoofer" where I highlighted my points that all speakers must be set al "Large" and subwoofer set as "LFE Only" to avoid frequency mixture. Since I found this new sub woofer with 3 RCA (Left, Right and LFE), I hope it can settle my problem if all 3 of them can be wired simultaneously. I post my question here because I can't find the answer from online Manual Instruction.
Here is an example: http://www.wharfedale.co.uk/Products/Product/tabid/78/PID/316/CID/318/language/en-GB/Default.aspx#detail
Thank you guys
Thank you guys
