drummerman said:gasolin said:drummerman said:Cypher said:Just read the review.
But I like to know how much of an improvement they are over the 2020i speakers ? Are they almost as good as the Concept 20 ?
Is it worth the investment when you already have the 2020i speakers ?
Maybe someone who did the review could answer these questions *smile*
I can't post links but if you go on youtube you should find a comparison one guy did with a relatively good microphone set up between the the 2020i and the 3020 both on stands and shelf standing.
Even on youtube the difference is quite profound.
Imho there is no question the 3020 is superior but I don't know how it compares to the concept.
https://www.youtube.com/watch?v=ieszSrVRIFA
Fantastic, cheers.
Improvements seem to be most noticeable in mid and treble clarity but even the bass seems firmer.
Provided the youtube video was reasonably accurate, to achieve similar improvements with amplification or cabling would probably cost much more than the difference between the old and new QAcoustic, discounts notwithstanding.
there shoud be some difference in the youtube video since the mic is the same, but the 2020i have double terminals and the 3020 only have single connection,terminals, is the 2020i used the the metal bracket on, the cable both for top and bottom or jumpers?
Would speakercable instead of the metal brackets give a much better sound on the 2020i?
 Facebook
Facebook Instagram
Instagram
