Q ACOUSTICS 1010i 5.1 SPEAKER PACKAGE
newaudio
33
ello ello
has anyone got the above mentiond package? is it any good and which amp are you using?
thanks
eamo
Ive not got the package, but i have auditioned them and found them to be excellent value, being that there isn't many alternatives for traditional speakers falling under £500, but at the the time i opted for some bargain Quad-lites instead. This was due to the fact that the centre was rather large and would not fit on my tv stand, else they would of been my choice especially over the Kef 2005.3. Now they have a price drop to £399 even better value especially as you can always upgrade the fronts to 1030i or 1050i floorstanders at a reasonable price. As for amp with the basic 1010i, Onkyo 606, 607 will work fine, if your planning a possible upgrade then i think the 875, 876 would be better. Looking at other amps Denon 1910, Sony 2400es or mid range Yamaha's also work well, audition for best results, but added features and connectivity may play apart on your decision. A popular package but also consider Tannoy arena lites, MA Vectors, Warfedale Diamonds and Tannoy custom f1''s.
I have the Q Acoustics package, with the 1030i floorstanders at the front.
I can highly recommend this package for music and movies.
I use an Onkyo 606, with an upgraded mains cable, with this package.
