Q acoustic 3020's
rojdijdoj
I have 2 pairs of q acoustic 3020's in each corner of a big room and desperately need a new amp. Can anyone recommend a decent reasonably priced integrated amp that would give me the best sound. Oh I might consider adding a little sub at some point too .. Thanks
rojdijdoj
the room is 9m x 9m wide ceiling height is 5m to the top of the apex, 3m to the sides. Budget around £400. I've just been using a Sony amp from cash converters. Cheers
rojdijdoj
I had a pair that we fine in our last living room, basically I have added another pair to save buying 2 new pairs for quad sound. I'm possibly clutching at straws?? Just looking to achieve a good sound from a well paired amp - perhaps with a bass bin or open to suggestions. Good to spend upto £1k for amp etc? The room doesn't have much in the way of soft furnishings either!
