C cheyworth Well-known member Jul 13, 2008 145 2 18,595 Jun 22, 2010 #1 Do they make (either pro-ject or other) an extension cable to go between my Pro-ject speed box and RP5? I am looking for about 2-3m. Chris
H Henley Well-known member Nov 26, 2007 1 0 18,520 Jun 23, 2010 #2 Unfortunately not, it's a nice idea though.
C cheyworth Well-known member Jul 13, 2008 145 2 18,595 Jun 23, 2010 #3 I am sure you couldmake one easily with thr correct plug/socket. what connection/voltage is it? Chris
C cheyworth Well-known member Jul 13, 2008 145 2 18,595 Jun 23, 2010 #4 would this do? http://www.icode.co.uk/icatcher/cctvshop/3m-2.1mm-power-extension-cable-p-382.html Chris
C cheyworth Well-known member Jul 13, 2008 145 2 18,595 Jun 24, 2010 #5 I have taken the risk and bought this... http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=380227270986&ssPageName=STRK:MEWNX:IT Will let you know how it goes. Chris
H Henley Well-known member Nov 26, 2007 1 0 18,520 Jun 25, 2010 #6 Excellent, we were going to try one but are happy that you're the guinee pig. 🙂
C cheyworth Well-known member Jul 13, 2008 145 2 18,595 Jun 25, 2010 #7 Do I get some sort of finder's fee or commission? Chris
H Henley Well-known member Nov 26, 2007 1 0 18,520 Jun 25, 2010 #8 For finding a £3.99 extension cable, you have our eternal gratitude. We found ours at www.CPC.co.uk 🙂 Seriously though, if ever you need any accessories, get in touch. We'll try to help a bit.
C cheyworth Well-known member Jul 13, 2008 145 2 18,595 Jun 26, 2010 #9 Well the extension arrived today, a bit of moving round and all is fine. As you would expect no change to the sound at all. I just need to improve the cable from RPM5 to Pro-Ject Phono Boz II. (need a1.5m cable) Chris
