emcc_3 said:Well a cable showed up today. Though to my disbelief it was the cheapest looking unshielded RCA cable and didn't even have a earth wire. When I called them they told me they had found it in the office and thought it was the right type of cable. Absolutely fuming this is supposed to be a hifi shop. They are going to send out the right cable but won't be here till the earliest Tuesday.
emcc_3 said:Well that didn't last long. Hum is back again. If I touch the platter it dies down a little. I'm flumuxed.
brownz said:Does the hum vary if you lift the tonearm and move it back and forth across the platter when nothing is playing ?
The Debut Carbon DC uses a wall wart and is double insulated, so no earth on the wall wart.
Where about's on this hallowed isle are you located. I would recommend getting it back to us as this is unacceptable for a new out of the box TT.
emcc_3 said:Spoke to richer sounds today and given the issues I have had they are giving me a full refund and some vouchers to make up for it. Can't fault them on the customer service side.
So now in the market for a new TT, though won't be a project unfortunately.
Looking at rega planar 3, any others I should look at?
emcc_3 said:It's definitely the turntable. Same issue on two amps at different ends of the house. My friend brought around his sony turntable and no hum. Also if you Google hum along with the model this is a very common issue.
emcc_3 said:Have returned the project for a full refund this morning. Picked up a rega planar 3 from audio T, who gave me £25 off as well :-D
Set up at home already. Not an iota of buzz even when the volume is cranked to full. Right out of the box this sounds quite a lot better than the debut with a lot less surface noise on my original pressing of Abraxas. Sounds almost like a new record.
