- Aug 10, 2019
- 2,556
- 5
- 0
Hi all, new here! I have a simple HiFi setup which has worked very well for quite a few years, but now after moving it the amp is giving a problem. The amp is an Arcam Delta 60 (yes, it's old!). I'm using an Arcam Alpha 7SE CD player and the amp is into Epos ES11 speakers (bi-wired). So here's the problem: In stereo I only get sound from one speaker, but if I press the mono button I get sound from both speakers. I opened the amp and there's nothing obvious amiss. I changed both the 2 amp fuses but that hasn't made any difference. At the moment I can't afford a new amp and even sending it away to be repaired is likely to cost more than I can afford. Anything obvious I may have missed? Anything I can try myself to test it would be much appreciated. Otherwise it's mono for me for the foreseeable future...
