Anderson
Also if it you want I could remote connect to your PC to troubleshoot sometime this week or next.
Anderson said:Also another one to try and this is a shotgun approach. Go into start, Run, type 'msconfig' without quotes and hit enter.
A new screen will appear with tabs, in the startup tab uncheck everything. Hit apply but don't reboot.
Now move to the services tab and check the box that says 'hide Microsoft services', now uncheck everything again, hit apply then reboot.
Do you still have the issue?
Dont worry, this is all easily reversed but what it will do is highlight if something you've installed is causing a problem at boot.
