- Aug 10, 2019
- 2,556
- 4
- 0
Can anyone help?
I have Primare CD31 connected to the Primare I30 Amp via Nordost Blue Heaven XLR connects, my speakers are Triangle Antal Esw's using XT400 cables and the components are in Atacama Equinox rack with plenty of space.
Normal listening is showing around 30-40 on the amp volume (max 79) which although appears a little high to me in the range, does sound fantastic: However, if I feel the need for a bit of indulgent loud music anything past 60 instantly muffles the sound to protect the amp overheating, similarily if I play tracks at a volume of around 55, then the sound cuts out (muffles) after 3 or 4 tracks. turning the sound down lets the pure sound return.
It's about £4500 of kit which you can't play loud seems mad! all the kit is 5 star rated award winners etc so what am I doing wrong? Sevenoaks suggested buying a pre-amp which seems like just throwing money at it.
is it something to do with 4 or 8 Ohm and if so how do I change the setting?
Any advice greatly appreciated - Thanks
