Hello forum.
Playing large iTunes library (most files in the Apple lossless format) on laptop through Behringer USB DAC into Arcam Alpha 8R/8P and then into Mission 752 Freedom speakers.
Mostly pop/rock/indie/electronica/hip-hop, some jazz, no classical. I'm not a hi-fi obsessive audiophile by any means, but would like to get the best out of the kit I've got (which ought to be pretty good).
Struggling a bit with tone controls, etc. If I switch off EQ in iTunes and use the Arcam amp in direct mode (bypassing tone controls) - as a purist surely would - it all sounds a bit flat & lifeless. I find myself wanting to whack bass & treble up to full on the amp and sometimes pushing things a bit further with the iTunes EQ.
I've weaned myself off the iTunes EQ. Not easy though because there's something superficially attractive, at first, about the big bass/sharp top end from the "double whammy" of iTunes EQ + tone controls. And yet after a while it does get quite tiring to listen to.
Not ready to ditch the Arcam's tone controls though. Should this bother me? Is the compulsion to go big on the tone controls an addiction of sorts? Are these things to some extent a case of "what you're used to"? Also, I'm 44 years old so I suppose my hearing at the upper end probably isn't quite what it was when I was younger (I had a hearing test recently, which was absolutely fine, but I guess "fine" is quite a broad definition).
Thoughts?
Thanks,
Alan.
Thoughts?
Thanks,
Alan.
