I've got the chance of obtaining either the OB1i's or (pre- curved) SCM 40's secondhand v.g.c., from different sellers; but there isn't going to be an opportunity to listen to them at home, or in the right environment before taking the plunge. Effectively I'd be buying blind, so to speak. Both sellers are about 100 miles away, in different directions from here.
Considering the price, it's a big decision to make. Should I take the risk?
I've read quite a number of reviews on both and know them by reputation, but have never heard them myself. So again, I'd be taking a bit of an expensive risk and could possibly fall in that obvious trap of not trying before buying..
I'm not sure if it will help, but I thought I'd try and gauge some thought about the relative merits of these speakers, before deciding what course of action to follow.
I don't think room size is too much of an issue (8m x 4m, carpeted with soft furnishings).
I'll be looking at a new amp, either integrated or power (stereo/monoblocks) fed by a pre + DAC or DAC+ pre. Suggestion welcome. Will the likes of the Naim Nait XS2, Rega Elicit-R etc, be a bit lightweight for these speakers?
Musical taste's inc. Acoustic, Jazz, Soul, Blues, Contemporary Alt & Rock, Classic Rock, Prog and Heavy Rock. Quite a broad spectrum sound wise.
Sources will include Sonos Connect, possibly a new HiRes capable streamer too, for ripped CD's, Spotify etc; as well as a CD player and Vinyl.
Thanks.
Thanks.
