- Aug 22, 2007
- 82
- 0
- 0
bigblue235 said:I'd seen people mention that elsewhere. I'm a bit clueless though
Did you consider those when you went for the DB1i?
Electro said:Or if you fancy saving yourself a few bob
http://www.production-room.com/pmc-speakers/pmc-db1s-plus/
The professional version .
hoopsontoast said:Electro said:Or if you fancy saving yourself a few bob
With VAT, they are just about the same price as the 'Gold' version![]()
Electro said:hoopsontoast said:Electro said:Or if you fancy saving yourself a few bob
Actually the price is including VAT![]()
http://www.production-room.com/shopping-basket.php
hoopsontoast said:Electro said:hoopsontoast said:Electro said:Or if you fancy saving yourself a few bob
Ah ok, just be weary from there, everywhere else seems to have them for £775 ex VAT or around £950 Inc VAT.
http://www.canford.co.uk/Products/76-237_PMC-DB1S-LOUDSPEAKER-40-150W-passive-studio-pair
http://www.millennium-music.co.uk/pmc-db1-s-studio-monitors-passive-pair
https://www.kmraudio.com/shop/monitoring/pmc-db1s-pair.php
http://www.clearangel.net/ProductDetails.aspx?id=h12023233
Usually if something seems too good to be true.....
TheHomeCinemaCentre said:The gold is an exclusive model for Sevenoaks - essentially the pro model. The key sonic difference is the better i series tweeter in the DB1i. At this level it is well worth considering the Twenty:21 from PMC
Zob20 said:Hello All,
I just wanted to correct a previous comment which suggested the PMC DB1 Gold uses a different HF from the DB1i. From the PMC spec sheet they use identical drivers. The Gold edition specifically says it uses the Solonex unit that What Hifi liked with the DB1i. Interestingly the DB1S+ spec sheet doesn't mention Solonex driver, but the description is the same (27mm soft dome etc.) so there me be nothing to read into this. Whatever, the DB1 Gold is black only DB1i as far it is possible to tell, the DB1s may be slightly different.
I have just auditioned the DB1 Gold at Sevenoaks HiFi. I have been searching for a satisfying small speaker to replace my enormous 10 year old Eltax LR6.5's (on instruction from the boss!). The Eltax's were cheap compared to the speakers I am auditioning now so I thought I would easily find something I was happy with but I have been sorely disappointed.
After listening through the options from Kef, B&W and others it was a revelation to listen to the PMC's. I had given up on any small speaker delivering anything but single frequency boomy bass from the port and compensating with tiresome midrange. The Kef R100, the best I heard until the PMC's, produce great detail and sizzle but only above 250Hz ish (based on my subjective assessment). They miss detail in the lower end and therefore rhythms are left without much holding them together. In short the PMC TB1 Golds were the first small speaker that I genuinely enjoyed listening to so I have put down a deposit. I didn't hear the LS50's because my amp isn't up to it.
I’ll probably post again when I have them home and I might have a different perspective.
drummerman said:PS. In response to the last post, I would not have described the DB1i's as cold or lean, quite the opposite, to colored perhaps. It tries to chew off more than it can handle in the bass at least that is what I think I remember. May be wrong.
