PLZZ plzzz help me....ONKYO TX-SR608 & Boston xs 5.1
binishkumarks
hi.....
i bought boston xs 5.1 speaker, am planning to buy onkyo tx-sr608...
i wanna to knw the abt the combination? hope tis is a gud combination?
And also i bought n extra boston subwoofer n 2 speakers. can i b able to get 7.1 effect? but then how abt the second subwoofer? is it possible to connect 2 subwoofer in the same same room itself? if then can u tell me abt the connectivity & placement of 2 subwoofer..?
And also i wanna knw abt the cables, especially to the speakers n subwoofer...?
plz help me replying to this thread at the earliest..!
thanks, Binish
Ronald Archiebald
63
binishkumarks:
hi.....
Yes
binishkumarks:
get 7.1 effect?
Yes
binishkumarks:
The TX-SR608 has 2 subwoofer outputs - look at the pre-out section. You can use both.
binishkumarks:
What exactly would you like to know?
