Please help 2nd hand amp
Trying to source a 2nd hand amp to power B&W DM602 S2 speakers budget of only £150.00 any suggestions welcome.
Speakers rated at 40 - 120 watts.
Thanks have looked at rotel RA-01 its rated at 40 watts per channel which is the minimum requirment of the speakers. I guess that should be ok.
d_a_n1979
134
Arcam Alpha 9 integrated...
You should be able to pick one up off eBay no problems and it'll drive your B&W's superbly...
You could also take a look at the NAD C320BEE integrated amp; should be able to pick one up for well under your budget. It's 50w per channel but believe me thats mnore than enough; the NAD amp reall kicks well :)
