Please can you help me in Rega Dac-r?
andrea
The new Rega Dac R with usb works at 192k.
I bought the optical cable qed performance graphite,connected tv,playstation 4,run at 48k.
Why?
The tv is Samsung ue40 c8000
Best Regards
Andrea
Because they output at 24 bit with a sample rate of 48kHz.
I know my TV and DVD player, etc. normally output 24/48 through optical.
Unless you are playing a music file with 24/192 resolution you aren't going to get that output. Knowing nothing about the PS4 I don't know whether it is capable of playing such files. Not sure what the situation should be if you are playing back a high resolution music bluray. Even then you may only be able to output certain higher resolution audio formats (certain dolby and DTS HD master, etc. formats) through HDMI, not optical.
Just because the DAC is capable of converting digital files up to a certain resolution doesn't mean all files are at that resolution. They may have updated the DAC so that it can now receive high resolution data through USB, but do you really have many 24/192 music files? Of course, if you set your computer's audio settings to upsample everything to 24/192 the DAC will show it is receiving 24/192 files, but this isn't really the point.
Many thanks for your reply .So may be that in the settings tv I can find a higher resolution ....Altro
No. I believe that resolution is the standard used (broadcast, etc.) and there is no way to get better quality/higher resolution by changing the TV settings.
The capability of the DAC to play back higher resolutions is pretty much only for the playback of high resolution files from a computer or NAS, etc. e.g. Music files like those sold by http://www.hdtracks.com, http://www.linnrecords.com, etc.
The PS3 was DLNA capable, so you could use it to stream high resolution music files from your computer or NAS, but I'm not sure whether this is possible with the PS4. I don't think it is DLNA capable, so you you probably can't unless there is some other workaround or app.
Hi Andrea
The TV and the DAC are both fine. You do not need to output 192K. You have just bought a DAC that CAN play 192K music files, but those files are rarer.
Please do not buy anything else as everything you have is OK.
