playbar connection issues
farawaydave
60
my tv doesnt have optical out options are as i figure.1 optical out direct from sky hd but not sure if it would work and are there lipsinc issues.2 some kind of switch/convertor analouge to digital cyp spring to mind or spend a £grand on a shiny new tv.
the first option also bypasses my bd player so a splitter might be required.
Tarxman
64
How old is your tv? You can run optical out from your sky HD box, though you may need to make a few adjustments in the audio output settings on the sky box.
The_Lhc
1,176
The Playbar itself also features lipsync adjustment as well I believe.
