Plasma screen cleaner
Panasonic Care Instructions:
Regular care: Gently wipe the surface clean of dirt by using a soft cloth.
Major contamination: Wipe the surface clean using a soft cloth
dampened with clean water or diluted neutral detergent (1 part
detergent to 100 parts water). Then, using a soft dry cloth, evenly
wipe the surface clean until it is dry.
I have done this with both my CRT and LCD and it works well. Microfibre is best.
Are we supposed to use distilled water as someone in another forum stated?!!!!!
Triple-distilled, preferably. And run through a Brita filter sever times.
Don't forget to take off the worryboots and check the door is locked before you go to bed.
[quote user="Andrew Everard"]
[/quote]
Are you stalking me Mr Everard?!!!
Checking up to see whether I have done my lines?....'I will not get screen burn'
I was joking about the distilled water but someone did say you should use this to clean Plasma screens due to the chemicals in tap water.
And you call me a worryboots!
Off now to clean my LCD and I will use microfibre cloth and spit. See I just don't care!!!!!
AE is wasted in his current position should have been a politician with his sarcasm oh i meant wit - sorry!
