- Aug 10, 2019
- 2,556
- 5
- 0
Hello WHT and others,
would be grateful if you could advice me on the choice between above mentioned players.
FYI: Play CD via separate Yamaha CDs-1000.
Was deciding between Sony 760 and Pioneer LX 52. After some reading on the forums decided to go for the LX52 (which seems to be seen by Clare as the better player).
Then got advice from a HIFI provider who prefrerred the LX71 over the LX52 (and clearly chose the LX52 over the Sony 760). Do you share that view (both views)?
Thanks in advance for the support in this decision process!
Kind regards,
Berry
Kind regards,
Berry
