Pioneer A-300R
Main problem is the phono stage - a let down in comparison to the A-400 according to reviews.
Thanks. Apart from phono stage, (all my vinyl is in the loft anyway), it would be fair to say it had a similar sound quality?
Yes, unless somebody can prove me wrong, there is little difference in sound quality - especially if your not using it on some £10,000 ATC reference speakers or something! Anyway, the specs show little difference.
It should be one cool amp!
Very good too but less power I believe. Thus, I would expect less control, particularly of difficult loads and higher volumes.
Yep, I bought it for £35.01 (compared to an Ebay average of £80 - £100 for an A-400).
Pretty damn chuffed.
