CnoEvil said:As long as the red line is connected to the same colour terminal on the amp and speaker..it can certainly be the +ve.
I would be surprised if you don't hear a difference....and if you do, hopefully you will like that difference.
Let us know either way.
DomCheetham said:CnoEvil said:As long as the red line is connected to the same colour terminal on the amp and speaker..it can certainly be the +ve.
The stripe is positive on both the amp and speaker. Yes, I will let you know what I think of the cable.
Benedict_Arnold said:DomCheetham said:CnoEvil said:As long as the red line is connected to the same colour terminal on the amp and speaker..it can certainly be the +ve.
The stripe will bat for either side. What's important is you connect like-for-like.
I used FOUR runs of Chord Odyssey FOUR cable for my old Cyrus setup with two X-Power, erm, power amps. Two cores terminated together at each end for each channel. One cable fed HF+ and HF- on one speaker, a separate cable fed LF+ and LF- on the same speaker. Repeated for the other speaker. I could bi-amp with the twin mono configuration X-Powers any way I liked.
Overkill? Probably.
Did they sound great? They sure did!
I've still got the cables sitting up in the attic in a box waiting for a hifi that justifies dusting them off and getting them re-terminated.
DomCheetham said:Benedict_Arnold said:DomCheetham said:CnoEvil said:As long as the red line is connected to the same colour terminal on the amp and speaker..it can certainly be the +ve.
Overkill? Probably.
Sounds amazing, I'm sure it did sound great. Cheers for the post, nice read.
Andrewjvt said:DomCheetham said:Benedict_Arnold said:DomCheetham said:CnoEvil said:As long as the red line is connected to the same colour terminal on the amp and speaker..it can certainly be the +ve.
Overkill? Probably.
How you getting on with the dynaudios? Now that you are used to the sound. Is your amp getting hot at high volume?
Overkill? Probably.
Al ears said:Andrewjvt said:DomCheetham said:Benedict_Arnold said:DomCheetham said:CnoEvil said:As long as the red line is connected to the same colour terminal on the amp and speaker..it can certainly be the +ve.
Overkill? Probably.
What makes you think the Roksan amp is going to get hot driving something like the M20's?
DomCheetham said:Andrewjvt said:DomCheetham said:Benedict_Arnold said:DomCheetham said:CnoEvil said:As long as the red line is connected to the same colour terminal on the amp and speaker..it can certainly be the +ve.
Overkill? Probably.
It's being repaired, I got an email from from Richer Sounds. Roksan are replacing a couple of sockets and it's having a full service and update.
TBH I would lying if I said I wasn't excited.
ATM I'm currently enjoying with the Cambridge Audio Topaz 10.
Andrewjvt said:DomCheetham said:Andrewjvt said:DomCheetham said:Benedict_Arnold said:DomCheetham said:CnoEvil said:As long as the red line is connected to the same colour terminal on the amp and speaker..it can certainly be the +ve.
Overkill? Probably.
Nice enjoy
