Question Phono Stage help!
GwMarshy
14
12
Hi everyone,
I am looking to change my phono stage and thought I had settled on the Rega MM fono mk5 but then different recommendations have come up and I’ve now confused myself. Below is my current set up:
Rega Planar 3
Rega ND3 cartridge
Wiim amp Pro
Ifi zen phono (1st gen one)
Bowers and Wilkins 607 S3
Rel t-zero 3
I think I’ve narrowed my choice down to the Rega MM fono mk5 or the Graham Slee Gram Amp 2 special addition but I’m after opinions which my be best.
I’m also open to other options but don’t want to go any higher than the £250 the gram amp would cost me.
Thank you!
Hi everyone,
Rega Planar 3
Rega ND3 cartridge
Wiim amp Pro
Rel t-zero 3
Thank you!
What's wrong with the iFi Zen phono?
Nothing imparticular, I was just hearing better things about the other 2
Waste of money then really.
Spend on upgrading the cartridge itself.
Both amps you mention will be good with moving magnet cartridges but whether or not you'll notice any difference over and above the iFi is debatable.
You will have to audition for yourself.
Phono preamps at this price point are designed to do a job and most do it pretty well however they cannot make a bad cartridge a good one.
Nothing against either personally but it's your money.....
Reactions: GwMarshy
I've had a few phono stages and the best bang for buck I've come across is the mofi studio phono....I think it's went up in price a bit for a new unit but I'm sure a used one will be in budget, whether it's better than what you have, I can't comment as I've never heard the ifi or Graham slee, but the mofi was at least as good as a project tubebox ds2 I owned....if you really want that phono stage upgrade your going to have told go above £500, say maybe Tom Evans microgroove , trichord Dino mkiii, ( the never connected psu is a nice addition to the trichord, but brings the price to over 1k) dynavector p75 and I'd also highly recommend the njc audio phono stage which I currently use ( only available in the UK)after all that you'll probably want to up the cartridge also.lol.....but before going to those levels of phono stage the amplification should probably be looked at......IF YOU'RE IN this for the foreseeable.
Thanks for this I have only just but the Wiim amp pro so that’s not something I’ll be looking at just yet!
Thanks for this I’m going to have a look at your suggestions
Hi everyone,
Rega Planar 3
Rega ND3 cartridge
Wiim amp Pro
Rel t-zero 3
Thank you!
Try a Graham Slee phono stage, I've been using the Reflex M for a few years, really happy with it. They have a loan programme so you can try them at home in your system , it's how I decided on mine. Worth checking out. In fact, I've got some of their interconnects on loan at the mo. Their website / forum has all the details.
Reactions: Clarkey_71
Thanks for this, I’m giving John a ring tomorrow morning to hopefully get one on loan
Hi everyone,
Rega Planar 3
Rega ND3 cartridge
Wiim amp Pro
Rel t-zero 3
Thank you!
You probably aren't going to notice much difference. To call your amp the weak link would be unkind as its a solid piece of equipment, but speakers and turntable on higher level. If you update your amp in future that may be the time to get a new phono amp, or even get an amp with a really good one.
Hi everyone,
Rega Planar 3
Rega ND3 cartridge
Wiim amp Pro
Rel t-zero 3
Thank you!
Hi, from my 30+ years experience with HiFi I think following:
1. iFi Phono is fine unit;
2. Wiim Amp Pro is better as streamer, but not so special as a HiFi amp;
3. Bowers&Wilkins 607s3 are again very good speakers + your Rel subwoofer.
So my advice is short: keep your iFi phono till you upgrade cartridge to e.g. Rega ND05, or ND07 or you uprade turntable to e.g. Planar 6. Than I recommend to take Rega Aria mk2 or mk3. This is a preamp which is a game changer in your system. Even mm part in this preamp is a mile better than Rega Phono MM. And take a look on matching amplifier first. Something like Rega Brio mk6 or Elex mk3 or Cambridge CXA 61 or 81 will work a lot better than Wiim Amp Pro. This is an invest, upgrade which will have higher added value for your system than just phono preamp upgrade.
BR. Juraj
BR. Juraj
My p3 was from around 1980 so I have now upgraded to the p3rs and the difference is massive already. Thank you for the advice
Yes, congratulation to P3RS. It is some 70-80% of P6 sound quality but for just 999 pounds in GB or 66% of P6's price. This is very good. Even Rega made P50 version of P3, I think real "Planar 50" is P3 RS. Like my old Planar 25, which came in 1998 as "cost cut" version of P9. It was also a real bargain, running and sounding still very good. Currently with Goldring Elite MC cartridge and via Rega Aria mk3 from last Sunday😊. I have used for P25 some 9 years Rega Aria mk1, than switched to Electrocompanient ECP 1 mk2 with dedicated power supply. Electrocompanient is very very good but Aria is just better! Happy listening to LPs! BR. Juraj
I had a Reflex C for a while. Always thought it punched well above it's weight. I moved on to a trichord Diablo and I couldn't say it was the upgrade the additional price suggested.
Have moved on since but always have fond memories of the Reflex C.
I have a GS Era V.
First thing to do would be to loan the Gram Amp and can then compare and see if there is any uplift. If significant then purchase. If not you have more money for records!
I tried a Rega Fono MM MK5 a few months ago and it was nice but not a massive upgrade over my amp's or turntable built in ones - so I returned it. Have not heard the Ifi so can't comment but I have read very good things about the Phono 3.
I see you have already made contact (hopefully) with John C at GS - extremely helpful chap. I didn't go ahead with the GS as needed a phono with lower capacitance but hopefully they will suit your needs.
P.s. What about staying with yours for a bit longer and save up for a better one, as it was suggested above? I just bought a used Simaudio Moon 110LP (for £360 - £560 new) and it's really good. Much better than the Rega Fono imho.
P.s. And upgrade cartridge, as Juraj suggested above.
Reactions: Integralista
What are the criteria you have to pay attention to before purchasing a phono stage ?
I read the association with the tonearm is the key.
For sure we will find tube and discrete component advocators. I would like to avoid tube phono stage.
What do I have to consider before bursting the bank or not?
The Fosi presented in the video is confusing me.
Don't know where you read that Ben, but it's not correct.
Fair enough, so would I.
Not sure what video you're talking about - but state the Fosi model and what it is you're confused about - and the people here will get rid of your confusion.
Thank you Gray for you post.
I am quitte a beginner in LP. I have been advised to consider at first the closer signal from the stylus to the speakers. Advice given by sellers and forums. I am not certain on that.
I pay now attention to my phono stage. This is why I try to read a lot and grab some advice.
Fosi is confusing to me with these low prices in the world of thousandKs. I offered a Fosi amp to my sister with small Eltax speakers and it's impressive (Debut Carbon + OM5). The sound is really good and the whole system is cheaper than my cartridge and phono cable.
Hi Ben, pls. which system, turntable, cartridge, amp and speakers you are using? This info will help to give some advice. To recommend just blindly some phono brand or even conrete model is crazy. Regarding amp technology used in phono, both meaning tubes and transistor are very good. Tubes are more specific and realy not easy to design and build high quality tube phono stage. From my experience tubes are better matching real highend turntable, lets say 5000 Eur and more. For "normal" peaple
Reactions: BenWatts
A Thorens TD-1500 with its stock TP-150 tonearm and Ortofon 2M Bronze cartridge.
Heed Obelisk SI3 and power supply X2 as amplifier
Acoustic Energies AE120 mk II speakers.
