Hi!
1) I've pretty much decided to go ahead and buy the RP3 with a Nagaoka MP110 Cartridge to be used with my current setup (CA CXA61 and Q Acoustics 3020i). I only need to save a bit more and I will order it.
Now, before pulling the trigger I'd like to know which Phono Stage you think would be a good pair for it.
I thought maybe the Cambridge Audio Alva Solo would be the best option because it would be matched with the CXA61 but I don't really know if that makes any sense, I'm just guessing. I've read that some people like the Shiit Mani as well. My budget for the Phono Stage is 200US$ top. I think I will never try MC cartridges, I might be just fine with MM that's why I considered the Alva Solo. Do you think the Alva Duo adds enough sound quality to justify the extra money invested? or is it just more expensive for the cartridges compatibility?
What's your suggestion?
2) My second question is: Would a 2mm spacer (I will get the Acoustic Signature one) be enough to adjust the tonearm VTA with the MP110 on? Is that the only extra thing I need to buy to calibrate and setup everything? This is my first turntable, so any suggestions would me much appreciated.
Thank you very much!
