Phono amp
d_a_n1979
134
I'm toying with the idea of getting a Project Debut turntable to add to my 2nd system and not sure which is the best route to go down for connecting it to my Arcam Alpha 9 amp Would it be best to get the phono extra added to the amp or is it worth spending a bit more and getting a good external phono amp? If so, what external phono amp should i consider and does anyone else have an idea for a different turntable? I dont want to spend more than £200 on the turntable as my vinyl collction is fairly limited!
John Duncan
2,033
27
19,720
Does the 9 not have a phono stage already? If it does, it will be a good one, I suspect (a forte of Arcam). If not, the CA640p is the best you'll need. 40 quid on eBay, 60 quid new.
d_a_n1979
134
No, most of the Arcam integrated amps have the phono stage as an 'additional extra'.
It is a consideration but i thought an external phono amp would be easier etc...
Plus getting a turntable/phono amp gives me an excuse to get a better equipment rack! I'm thinking Atacama....
John Duncan
2,033
27
19,720
[quote user="d_a_n1979"]No, most of the Arcam integrated amps have the phono stage as an 'additional extra'. [/quote]
OK. You might be hard pushed to find the plug in board now, though I imagine it would be good quality. Can't go wrong with the Cambridge though (I have one sitting in what's not exactly a cheap system, and don't doubt its ability)
[quote user="d_a_n1979"]Plus getting a turntable/phono amp gives me an excuse to get a better equipment rack! I'm thinking Atacama....[/quote]See, now you're talking. And re: Atacama, not much point in looking any further, probably.
[quote user="d_a_n1979"]I'm toying with the idea of getting a Project Debut turntable to add to my 2nd system and not sure which is the best route to go down for connecting it to my Arcam Alpha 9 amp
[/quote]
I have just acquired the Rega Phono Mini which i have set up with my Cyrus and Project and to me it sounds fantastic. Hard to compare it to others though as my previous Arcam A80 had one built in. £55 brand new which is pretty good though.
John Duncan
2,033
27
19,720
[quote user="chiefbrody"][quote user="d_a_n1979"]I'm toying with the idea of getting a Project Debut turntable to add to my 2nd system and not sure which is the best route to go down for connecting it to my Arcam Alpha 9 amp
[/quote]
I have just acquired the Rega Phono Mini which i have set up with my Cyrus and Project and to me it sounds fantastic. Hard to compare it to others though as my previous Arcam A80 had one built in. £55 brand new which is pretty good though.[/quote]
Ah but the Cambridge has a cool blue light ooooo
[quote user="JohnDuncan"][quote user="chiefbrody"][quote user="d_a_n1979"]I'm toying with the idea of getting a Project Debut turntable to add to my 2nd system and not sure which is the best route to go down for connecting it to my Arcam Alpha 9 amp
[/quote]
Ah but the Cambridge has a cool blue light ooooo[/quote]
I can't beat that i'm afraid!
gregory
45
i could have sworn all arcam amps had a phono stage,a little button you depressed with a pen at the back.it's a tiny hole but i was sure it's there.if not then ca 640p is a good start,have to admit didn't know about the rega mini phono does it not have a cool red light.
[quote user="gregory"]i could have sworn all arcam amps had a phono stage,a little button you depressed with a pen at the back.it's a tiny hole but i was sure it's there.if not then ca 640p is a good start,have to admit didn't know about the rega mini phono does it not have a cool red light.[/quote]
It does have a cool red light yes. All i know is, it sounds very impressive.
gregory
45
nice one,i had the rega ear amp and much prefer a red light especially on black,i must check it out. does anyone know if the arcam has a phono input to help dan out.might save him a bit of money or do you want that rack dan.
John Duncan
2,033
27
19,720
From Arcam's web site:
"Arcam's Alpha 9 integrated amplifier [snip]
(note that the plug-in phono stage, which caters for both MM and low output MC cartridges, is a dealer fitted optional extra)."
So there we go.......an Arcam dealer might still be able to find and fit a board, but I would suspect a 640p would be cheaper and at least of comparable quality. With a cool blue light
[quote user="JohnDuncan"]From Arcam's web site:
.[/quote]
Red light Vs Blue light!!! Nothing to do with sound quality?
John Duncan
2,033
27
19,720
[quote user="chiefbrody"]Red light Vs Blue light!!! Nothing to do with sound quality?[/quote]
Well the 640p did get 91% from HiFi Choice.....the blue light's just the icing on the cake
