I fancy a Cyrus 8 DAC to replace my Roksan Kandy LIII and Arcam rDAC, but the Cyrus doesn't have a built in phono stage. What dedicated phono amps should I audition to be at least as good or significantly better, if not too expensive, as the Roksan?
plastic penguin said:You'll be hard pushed to better the Roksan built-in phono stage.
ifor said:plastic penguin said:You'll be hard pushed to better the Roksan built-in phono stage.
OK, but I'll need one if I upgrade the amp, so what should I consider?
Alears said:You don't say what your cartridge is but i am assuming its a moving magnet.
I'd recommend a trichord dino - if you can get one second hand at a good price you can't go wrong. Also it will handle a MC cartridge when you feel like upgrading. I moved from my roksan kandy to trichord - night and day resultifor said:I fancy a Cyrus 8 DAC to replace my Roksan Kandy LIII and Arcam rDAC, but the Cyrus doesn't have a built in phono stage. What dedicated phono amps should I audition to be at least as good or significantly better, if not too expensive, as the Roksan?
gbhsi1 said:I'd recommend a trichord dino - if you can get one second hand at a good price you can't go wrong. Also it will handle a MC cartridge when you feel like upgrading. I moved from my roksan kandy to trichord - night and day resultifor said:I fancy a Cyrus 8 DAC to replace my Roksan Kandy LIII and Arcam rDAC, but the Cyrus doesn't have a built in phono stage. What dedicated phono amps should I audition to be at least as good or significantly better, if not too expensive, as the Roksan?
it's connected to a pro-ject experience 2 turntable with a Rondo Red MC.ifor said:gbhsi1 said:I'd recommend a trichord dino - if you can get one second hand at a good price you can't go wrong. Also it will handle a MC cartridge when you feel like upgrading. I moved from my roksan kandy to trichord - night and day resultifor said:I fancy a Cyrus 8 DAC to replace my Roksan Kandy LIII and Arcam rDAC, but the Cyrus doesn't have a built in phono stage. What dedicated phono amps should I audition to be at least as good or significantly better, if not too expensive, as the Roksan?
Interesting. What does your Dino feed?
Openwave said:Read it elsewhere,people use Croft RIAA (new unit GBP500) phono stage instead the K2 phono. Havent seen a review on this unit, however Croft products are generally deemed as top quality.
I'm Trying to get a demo this weekend of the riaa.
