Panasonic TV help needed
Chrismanc04
Hi all
i have a Panasonic to that a friend kindly have us. I have a couple of issues with it. When in hdmi 1 there is a strange buzzing like when a scene changes on screen - only happens on hdmi 1. To add insult to injury on HDMI 2 this works for for what can be days. Then suddenly the volume and mute button will start freezing and the tv will auto switch to digital tv. Any help would be much appreciate
Has the fault been present since your "friend" gave it to you, or has the fault developed only recently? If unplugging the set from the electric mains, waiting about 10 to 15 seconds and then plugging it in again (not just switching it on and off, you must detach it from the electrical supply) doesn't work, then you'll have to contact a local television repair shop, or Panasonic UK to arrange a repair.
Might just get a new one - was just a freebie I thought I would take advantage of. Just need to convince the wife now...
