Panasonic GZ950 v LG C9 (55inch)
Dan.m
43
Anyone have experience of either TV? Both available for £1499. Even though reviews suggest the pana has better sound I am mainly interested in picture performance.
So, this kinda sorta depends on how much image matters to you. The GZ950 is probably going to give you the higher quality picture, but doesn't quite have as many of the features as the C9.
Apparently the Panasonic Oled has a crackle to the TV sound according to some reviews and users experiences. I had the E9 briefly and the sound was giving no crackle sound, I hear okay things about the C9 sound too but they also say the sound is a little weak, comes with AI sound option to boast the sound this was very effective on the E9. Good luck with your choice.
The Panas did have a sound problem... you do an update when you buy them and then they're all sorted 🙂
